!997 v-max 600 xtc it seems to be hard on clutch bushings. Any one else have that trouble ? What are you replacing them with ? Yamaha or aftermarket ? Thanks for any advice .
Batwolf
I have the same issue. But the twins do vibrate.. I replaced bushings and rollers with stock, but then also went through and cleaned the primary because I honestly neglected it a tad too long. I almost want to check the balance because just one of my roller bushings was totally shot, and the corresponding fly weight bushing was wallowed too.
drew24
The twins are notorious for being hard on clutches. I recommend only oem parts. I tried one of the aftermarket kits and had to grind the bushings to get them to work. I had both the primary and the secondary kit and had to grind both sets.
