Sleepnfast
What would the stock clutch set up be for an '02 Viper ? Also what application came factory with 8bu's ?
viper uses 8ek weights with yellow/white/yellow spring with 14.5mm rollers.
the old vmax4 from 95-97 use 8bu00 and 8bu10 weights
drew24
The 8bu-00 was on the 95 vmax-4 and the 8bu-10 was the 97 vmax-4. The viper was 8ek. Look on a site like partzilla that has oem parts. Look under primary sheave and you can see which weight a particular model has. Mrviper beat me to it.
Sleepnfast
Thanks guys
