G gradzz New member Joined Dec 5, 2004 Messages 18 Location Port Washington, WI Feb 1, 2005 #1 Can you widen a SRX by using XTC/SXR radius rods and tie rod ends? Will this lower the ride height? onrof New member Joined Jun 2, 2003 Messages 5 Location Cadillac, MI Feb 1, 2005 #2 Sure, I did it, but you have to change the sway bar also then used the stock shocks. You must log in or register to reply here.
