Final Overdrive ratio
J_hubbs
Cedar Springs, Mi
Hey Fellas! What is the final overdrive ratio of our CVT?
I am using a SX700 engine and clutches.
I have read 1:1.25, but others say it only goes to 1:1.
Also while we are on the gearing topic, is the initial ratio 1:3?
I have AAENs clutching bible, but I wanted to verify the ratios with the Yami-heads on here.
Back story: I am using a redhead 700 to power a small car. Hence the gearing questions. The build is in the working log: Yamabishi
Thank you for your time
Your not really going to get a answer that will work for you.
The weight, how you convert belt to shaft drive, total hp... all will move your number
Plug in 1.1 to do all your math / setup. If it does go past 1.1 when it's all said and done. It's a bonus.
