On high mile sleds, #18 and #20 might work their way loose from #13. I had that happen on my 2002 SRX a few years ago, now it happened on my 2001 MM.
It leaked gas while on it's side for rear suspension tuning.
http://fiche.worldofpowersports.com...e=yamahasnow&a=259&b=20&c=0&d=-FUEL-TANK-ASSY
PZ 1
- Mar 12, 2005
Thanks for the information. If it leaks fuel there, it would also likely suck air - which could cause running problems and possible engine damage.
Usually the fitting #13 comes apart from the hose shrinking. Reroute the hose and reassemble the connector.
staggs65
That's the vent line. It's open to atmosphere
