I am going to install a sno pro hood on my 1978 srx 440 and i know about the thermostat housing clearance and the radiator clearance, but one issue i am not sure about is the air box? Will it fit? Or do i need to run velocity stacks with screens? If so where can you purchase these stacks? the air box side of the 38mm mikuni's I am running is 62.25mm any help would be great. Thanks
robroz
how did you make out snp pro hood
Hi good, thinking of doing the same 78 srx to sno pro hood, how did you make out
Thank You
Robb
Thank You
Robb
Yamaha Nutz
nope air box will not fit and stock radiator will not clear
