quick transfer rod question
Sx700
Glen Ellyn, IL
If I tighten the stock transfer rods it will increase ski pressure right? And if I loosen it will decrease ski pressure?
Depending On What Sled. If They Are Factory Non Adjustable You Cant Do A Thing To Them Other Than Changing The Spacers. Ski Pressure Is Adjusted By The center Rear Shock Spring Pre Load First( Recommended) And If That Doesnt Help The Tighten The Limiter Straps Equally A Little At A Time To The Point Where You Have The Ski Pressure You Like, But By Doind The Straps This Also Shorten The Travel Of The Center Rear Shock Hope This Helps, If You Dont Understand The Procedures I Wouldnt Recommend You Do This And Take It To A Dealer Or Someone Who Does.....
