Blisteringsnorider
Question...78 SRX has a bottom end bog until she winds up..is there any way to clean that up a little?? Been messing with the pilots and air screw but can't quite get it all to clean up. Thanks in advance for any advice
Did you check to make sure the clutches are moving freely?? You could raise engagement.
Blisteringsnorider
Yeah everything is free...I already engage between 5200-5500.. the bog is below 4500 RPM
80_srx440
They are dogs below 5k . All the power is up higher . Just the way they are
Blisteringsnorider
Kinda figured that from memory from back when they were new...just thought there might be a way to clean it up...Thanks
