Looking for engine parts for Yamaha GPX338G (free air engine)
jfpsteve
New Brunswick,Canada
I am rebuilding a 1975 GPX338G free air engine. Need a bottom end for my engine. Yamaha free air 340, 440, Sno Jet Thunder Jet 340 ,440 and a few others are the same. Any parts out there available? Mainly need crank but would like a complete bottom end if available. Thanks.
Be careful the bottom half of the case is the same for a 340 or a 440, the crank also but the top case is different for the larger 440 cylinders. I may have a 440 crankcase with crank.
while the bottom half of the case is the same for 338 and 433 never miss match cases they are a set and finish line bored that way ...........do you need a crank or crank and cases? do you have a crank that just needs to be rebuilt if so I rebuild them
