JERSEYJOE
Can someone recommend a flywheel puller for the Yamaha triples?
shaggyzr2
Batwolf
I have this one and like it.
https://m.denniskirk.com/283263.sku...m_medium=cse&gclid=COrGpt_yvsQCFQeNaQodDEMA8Q
Mac
I have one for you Joe. When your here take my clutch puller, power valve harness tester, flywheel puller, clutch alignment tools, and anything else in my garage you might need.
---Mac---
---Mac---
JERSEYJOE
Tools
OK thanks BOB but I hate borrowing stuff. When and where is a good day / time for lunch?
Mac
I will call you and set it up
rx1jim
Joe,
When you thread the three bolts into the flywheel, be careful not to thread them in too much. If the bolts are threaded in too deep and you rotate the flywheel, even slightly, the ends of the bolts will damage the stator.
Jim
Jim
JERSEYJOE
joe,
when you thread the three bolts into the flywheel, be careful not to thread them in too much. If the bolts are threaded in too deep and you rotate the flywheel, even slightly, the ends of the bolts will damage the stator.
Jim
ok thanks jim. Good to know. Lucky for me i am a friend of mac who is a viper wizard.....
