Head Gasket Mod pipes and compression
nelsonhouse
canada
what is the compression after you peel one layer on a 700 red head? and also after peeling two layers?
why does it recommend only peeling one layer with triple pipes?
i have a drag race on Saturday April 4.
500 feet.
i have some vp racing fuel C12.
will my redhead be okay if i peel two layers and when i and some C12 to 91 octane gas?
i have been told to mix it 50/50, C12/91 octane.
will this work out.
mods to my sled
P.S.I stock blaster pipes.
vforce reeds.
ported airbox.
heel clicker clutch. redspring
dalton helix 51/43. green spring. 80 degree
winter is almost over. 1 more month to go on the lake.
i'll be rebuilding the engine this summer.
My 700 redhead pulls in the 145 range on all 3 jugs cold. Pulled in the 125 range hot when I fouled a plug and needed to checked compression just to be sure.
From what I've picked up here and there 140's seems to be the high range for a stock head gasket. I put up a picture of the gasket rivets in the sled and it appears to be stock was the concensus. The one thing I know, when I first pull the sled over cold I gently bump is through tdc on each jug. It feels stiff enough I could damage something in the starter otherwise.
500 feet.
will this work out.
mods to my sled
vforce reeds.
ported airbox.
IMO, you won't have time to test and setup after pulling head.
You will see more gain in jetting for that day, go a tad lean and burp the throttle alot after 500'.
Work on your setup for 60'. When you pull someone by a sled at 60', it takes real good hp to pull even and pass you
Pics
Spark plugs. Pto plug left on pic. My plugs are reading a bit lean at -2. Forcast for weather is -8.
50/50 mix of C12 and 91 octane will give me 99.5 octane
is this too high octane, for one layer gasket?
99.5 Octane
( [ % Fuel A ] x [ Octane of Fuel A ] ) + ( [ % Fuel B ] x [ Octane of Fuel B ] ) = Octane of Mixture
