Srx case vs. Viper case
OK good. then I'll keep the case from the Viper and start to build the killer SRX motor for project BLACK SRX. Tony: I know the Viper crank is lighter so should I use it vs. the stock SRX crank for hot trail sled? The one that came out of the Viper has 1 bad small inner main bearing so I might send it out to Northern if I decide to use it. I wanted to keep my present SRX motor intact and original and piece together a spare one.
