viper board exchangers
maybz
Listowel, Ontario
Just wondering if SRX running board exchangers would work with a 02 viper for exact fitment. Thanks in Advance any help is always appreciated
Yes they should work. The SRX should be a little wider but the boards are the same other then the hole pattern in them.
yup just did it myself last summer!!!use 2000 or newer and grab the rear he whie your at it!!
They are an exact fit. The difference is they are thinner and hold less coolant and have alot of the sides removed in between rivets for weight and to not show through the holed tunnel of the viper. They can even be used on four strokes, some need changes to the front inlet for this. all your rivet holes should line right up
