Redhead
Hammer Down
Flint
Why do some have heated carbs and others don't.? Can a head/topend that has the cooLant hose to the carbs be swapped to a motor that doesn't? Also, will the carbs inter change ?
It was added to prevent carbs from icing in deep snow usage. You can just plug the head line location, its not needed most of the time I turn them off anyway.
X2 mr sled! I have wanted/used them on some high humidity snow days. They help in theses conditions to keep from bogging. If you remember you have it.
