RIVERRUNNER
jaydaniels said:Where is this other tread. Can someone post a link?
Here it is...
http://www.totallyamaha.net/forums/showthread.php?t=57871
jefsnow said:in montreal. canada. last night, after three days in a frigid warehouse, - 15 c, over 50 pulls................. grrrrrrrrrrrrrr................
Dogpoundracing said:my 2000 top gun 800 was a bear to start the begining of the winter took 20 to 25 pulls to start no matter what temprature it was but once started for the first time would run all day even after sitting in minus 10 with one pull tryed everything rebuilt fuel pump ,cleaned carbs again .The fix was all in the choke adjustment now it can sit on my trailer or outside overnight and starts within 3 pulls the most the first time after that one pull.
TJ500 said:still would like to see a picture of a primer bulb installed... are you forcing gas through the fuel pump when priming?
