extremeviper
got a vmax4 runs good wont turn off with key or kill switch switch and key ohms out good what could it be
extremeviper
how do i get this sled to turn off ??? checked all the grounds where are the ground blocks 92 vmax4
usually on the older sleds, it would just ground out the coils when you hit the kill switch or turned ign off. sounding like you need to go through the wiring harness and make sure all the grounds are good as well as the ground blocks.
extremeviper
grounds test good wont shut off even with the black white wire grounded think it might be the CDI
Thats odd, have you put a tester on the wires to the kill switch.. and or the key switch?grounds test good wont shut off even with the black white wire grounded think it might be the CDI
