Skis for '94 Ovation and '95 Phazer
kinghornmike
I am still rocking the steel skis on an Ovation and Phazer for kids and want to switch them out with plastic skis. Google is all over the place with what skis might fit. If I go to a salvage yard what type of skis could I pick up to fit on these sleds?
You can also use the plastic Yamaha skis from Apex, but you would need to remove some plastic in the saddle and use the rubber from the older ski.
here is what i did on my 97 et410 witch is the same tss as the 2 sleds you posted. still using the same set at this time and have only replaced the carbides/wear bars.
pretty much any aftermrket ski that will fit on a procross artic cat will work as well.
i did mine with a jig saw and a drill to start it. it can also be done with a plazma cutter. i did clean mine up with a file after i cut it.
