Results 1 to 5 of 5
Thread: 1995 phaser 2 parts interchangeable?
  1. #1
    Member Mini
    Join Date
    Dec 2010
    Rice lake wisconsin
    Posts
    90
    Thumbs up 1995 phaser 2 parts interchangeable?
    hi all I recently got a "low mile" phaser 2 1349 miles that had been sitting for a few years upon further investigation I need some parts! are the reed cages engine parts the same on phaser 2s? My rubber reed pads are shot I need both reed cages with reeds would like to keep stock. All or most of fuel oil lines are harder than martian algebra any helps appreciated I found most parts at arts parts near bloomer wisc I started replacing lines from pump to carbs with 3/16 fuel line I'm going to replace fuel oil sight lines too etc those are 3/16 also oil inj lines are same waiting for warmer temps I work outside on my trailer.
  2. #2
    Senior Member Stock Srx007's Avatar
    Join Date
    Jul 2014
    Cambridge Ontario
    Posts
    121
    Default
    yamahapartsation.com, have part diagrams and numbers from 2018-1968
  3. #3
    VIP Member A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,294
    Default
    Find a chainsaw/small engine shop that carries OREGON brand fuel line. The Ace/Stihl close to me has all the different sizes. It is very flexible and can take really tite angles w/o kinking.
    Tygon is E10 compatible.
    Oregon is E40 compatible.
    It stays flexible substantially longer.
    Dannyboy
  4. #4
    Member Mini
    Join Date
    Dec 2010
    Rice lake wisconsin
    Posts
    90
    Default
    Thanks ill check it out db
  5. #5
    Default
    The fuel lines are metric sized.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
