wisc93ex570-2guy
hi all I recently got a "low mile" phaser 2 1349 miles that had been sitting for a few years upon further investigation I need some parts!
are the reed cages engine parts the same on phaser 2s? My rubber reed pads are shot I need both reed cages with reeds would like to keep stock. All or most of fuel oil lines are harder than martian algebra any helps appreciated I found most parts at arts parts near bloomer wisc I started replacing lines from pump to carbs with 3/16 fuel line I'm going to replace fuel oil sight lines too etc those are 3/16 also oil inj lines are same waiting for warmer temps I work outside on my trailer.
Srx007
yamahapartsation.com, have part diagrams and numbers from 2018-1968
A couple of bucks
Find a chainsaw/small engine shop that carries OREGON brand fuel line. The Ace/Stihl close to me has all the different sizes. It is very flexible and can take really tite angles w/o kinking.
Tygon is E10 compatible.
Oregon is E40 compatible.
It stays flexible substantially longer.
wisc93ex570-2guy
Thanks ill check it out db
