what is that clutch set up you have for the sx700 with a bored silencer and how much would the part cost
					I run the 8ab weights on my sx sled, for a 97 try 8ab w/2.4g in both holes, y-s-y primary spring, 1 engagement shim, 15 mm rollers, 48/43 helix, green sec spring at 70 or 80....bore silencer, 1 layer head gasket, and notch the reed cages.....call Larry at North Country Yamaha 715-453-2626 for parts.
