488 venture 121 sled with reverse and electric start
1yamaha1
nome
can some body set me straight about my chain case its a venture 488 with reverse , i broke the chain case housing and would like to take the reverse out replace it with a different chain case , will a phaser chain case work with out reverse , or they the wrong bolt pattern , i took the pic off the web mine is like it
I have not done it, but it has been told here that the Venture reverse chaincase will not directly bolt into a Phazer. Whether a Phazer case will bolt into a Venture, I do not know.
Why would you not want reverse?
