MountainMax
RE: Mountain Max Belt Problems
Hey guys, im losing belts on my mmax700 alot, usually at wide open throttle, im using the stock 8DN ones and the center to center and offset are correct, I even have stiffer motor mounts and a torque stop on the engine, any ideas???? the belt always goes the same way, the top ribbed part seperates in peices from the main belt part which stays in tact, enough to drive home on but there are no ribs left on there. The only thing I can think of is im running an overdrive inner shieve on my Stock Yamaha Primary clutch, could this be pushing the belt too high?? Thanks for any input.........
