viper customization
Ontario
here are a couple of pictures of my sled.... sorry about the pictures being sideways... I have painted the hood vents and hinges white, just wondering what else you guys think I should paint and what colour. or if you have any other mods I should do, thanks!!
Where do you ride the powder? I'm looking for places to ride this upcoming season...you could probably remove those ski loops and put on some white ones...I'm guessing that's what ACB was going to mention...
I ride in woodstock and lonon area. I ride the tree lines and ditches, drifts, along with a couple of hilltop spots where there is sometimes 3 feet of powder.
White ski loops was what I was thinking. Get some white duct tape and start w/a strip that covers the inside of the loop. Then put a strip on the outside of the loop to cover the remaining blue. Prep w/Naptha and use a heat gun to aid in adhesion.
Also, if you could add a bit of white up @ the mirror area. Is there a molded in place on the back side of the mirror that you could add some paint to.
Thanks, I will try that and see what it looks like! And I don't have mirrors..
My bust. I was picturing the hand guards in my head and mirrors is what I put down. I was thinking of a white accent stripe. The mind is the first to go.
No worries! I was thinking about putting white on the hand guards, but I don't know what to use that won't chip when I hit a tree branch...
That would look wicked! What would you suggest to paint the tunnel?
Aluminum wheel paint would work good aswell as most automotive quality enamels like "engine paints" On the running boards you can use a bed liner so it wont wear off and it will give you alot of added grip over the bare metal.
Do you have any pictures of what you stated before done to a sled? I just don't wanna do it, then not like it and struggle to get it off...
Ive seen it done on vipers before but now all you get is 2014s when searching for anything viper related. Just look at the older sx sleds that came factory with a black tunnel. If your unsure you can plasti dip or vinyl wrap the tunnel for removeability.
just sayin,,,,mirrors are good,,,,, if you dont know, sooner or later you will be run over.............
