srx clutch ?
tooold
How much gain are you getting with a good clutch set up? is it worth it ?
Having your clutches set up right will make all the difference in the world. It is worth every penny you spend on your clutches within reason, and the setups recommended on the tech page that use oem yamaha weights will be very inexpensive. There are some excellent clutch tuners on this site, if you let them know all of the specifics of your sled, including all mods, and the conditions you ride in, maybe somebody can give you a baseline clutch setup to work from. If you like your srx now, you will love it once you are efficiently getting its power to the ground.
Thankx but how much do you gain when I had my rx1 clutch Iwas told I would gain 12 lengths in 1/4 mile and it did ;)!
