gearing and clutching
shaggyzr2
Central Wisconsin
If I wanted to lower my gearing a little on my SRX would I have to do anything with the clutching? The sled is all stock, just wanted to drop one tooth on the upper gear.
What ratio are you running now and what will you be going to? It won't cost much to try, but I'd guess that you will need to reclutch to get the most out of it. All things being equal You'll be lightening the load on the motor so it will rev faster and will want to over rev due to seeing less load.
