Youllbe2nd
Wondering what peoples thoughts are on honing nikasil cylinders. I've heard mixed opinions on whether your supposed to or not. I always have... 20 or 30 seconds to de-glaze and get the cross hatch back. I've never had a problem but I've HEARD you can chip the coating around the ports... Thoughts??
Sent from my E6560C using Tapatalk
I've never had any problems.  I always hone mine when rebuilding a motor. Or re-ringing it
			What grit and type of hone do you use? Ball type or stone?
			Youllbe2nd
Stone
Youllbe2nd
It just says medium grit
Haucks just honed mine today and they look great!
			Crash club
Top 2-stroke engine builders say honing a nikasil cylinder is a no-no. The coating is only  .002-,003 thick.
			Mac
A very controversial subject.  Ball hones works great in my opinion @320 grit.  They dont remove any material that you could measure so the plating thickness is not a consideration.  You run the hone up and down the cylinder for 8 -10 seconds or so with trans fluid.  We are creating a rough surface so the rings wear and break in.  Legend has it that someone once chipped a port.  And that legend lives on....  and is repeated forever.
---mac---
			---mac---
I've done it for years, no problems here. Just do it enough to give some cross hatch.
			Same with me.I've done it for years, no problems here. Just do it enough to give some cross hatch.
