When changing the length of the skid do you have to change where the suspension bolts ? I'm going to make my phazer 136. Do I have to move anything or is it a bolt up and go? I know i need to make my tunnel extension
You don't change the skid mounting points unless you don't have long enough rail extensions. I have the factory 121-136 extensions if someone can use them. I used a Arctic cat bumper and the pro rmk boards picked up used for 100.
spirudamax750
Thanks and pm sent about the extensions
http://minneapolis.craigslist.org/csw/snw/5419482148.html
Here's a couple I thought about buying.
Did one of you guys buy the boards from this ad? brand new take offs for $35 they are gone now.
Jean-Francois Aubin
is not me, but i jhave send email to this seller and i never receive answer. 35 is very cheaper price!Did one of you guys buy the boards from this ad? brand new take offs for $35 they are gone now.
Jean-Francois Aubin
Had to add some tunnel stiffeners to the back. Was a little week there. Just got them off a pro. Worked out well. Strong now.
Very beautiful job!
Jean-Francois Aubin
Hi Turblue, this part is sold new? Do you have part number?
Basically the boards and tunnel brackets are off a 13-15 Polaris pro rmk. If you look online Polaris parts on the model can get them there. Just find someone parting out pro. What I did. These boards aren't a direct bolt and fit. Takes a bit of cutting and drilling to get them to fit.
BigMan76
Those WRP Wasatch Recreational Products though; if they are straight bolt-ons, I might grab a set or two!
Well works awesome. Had a couple close calls with the Springer brakes. So added hydraulic.
http://vid61.photobucket.com/albums/h60/Turblue/Mobile%20Uploads/trim.CEC1F734-069D-493A-88D3-9C901556773C_zpszybircsy.mp4
guigui
you wouldn't happen to have a picture of the brake caliper bracket?
the bracket looks good. odds are you might get some requests for them as there are other riders who would like to convert to hydraulic brakes too.
Wow, nice work!
Did you have to change much to fit that lug height??
Also, What brake system is that off?
Appreciate if you have time to reply...cheers!
Dude didn't reply....
So I bought his sled instead.....lol!
CraveSingletrack
Sorry to dig up an old thread, but any specs on the skid setup? I'm putting together parts to do a phazer long track. build this summer.
It all depends on what skid you are going to use.Any specs on the skid setup ?
I'm putting together parts to do a Phazer long track build this summer.
What specs are u looking for? It's a Stock 136 skid, mounted in stock location. Rail extensions lengthened to accommodate the 141" track, idlers removed, and 2 wheel rear axle installed.
