M10 install in a viper
drew24
NW Indiana
Just got the m10. Does anyone know the correct mounting location? I found you can use stock front hole with a different front shaft. I think that is the way I would like to go. Any suggestions?
I also got this front shaft off of ebay. I think it was from a Polaris m10. Not sure if it is right or not. It fits the front arm but would be too wide with the thick front aluminum brackets. If the stock front hole works I could make this shaft work with a couple shims to make it the right width of the tunnel.IMG_20150908_144408964[1].jpg
do a search, there was a thread somewhere that told us how to mount without buying the mounting kit from fast. Very simple. I believe the thread was for a SRX, but the Viper will be the same.
I found a few different ways to mount it while searching. The center measurement is 25.55" but not sure on the height. I found one that said just move the outside plate forward until you get 25.55". Does that work? I haven't found much as to a measurement from top of tunnel. There was a thread that said it would be a little higher than the proaction rear hole was. Not sure which to use or if it would make much difference as long as I had the 25.55"
I have the paper work from my airwave install on my SRX. Let me know if you want me to pdf you the paperwork and I think I might have the template. I will check at lunch. Actually you can go to FAST site under install and see the info. I will check on the template though
drew he sent the pm to me for my install info. I have it all here at work with the template. send me an email address and will send off to you.
todd
That explains why I didn't get one.lol I will send you my email. Thanks Guys
