CaptBillvmax700
has anyoone on here ever replaced a stator? i just ordered one the other day and thinking about doing it myself. i have seen a couple videos on it already i didnt think it looked too bad. i also ordered a clutch puller too. just wanted to know what you guys thought about changing it.
Its a pretty painless replacement.
CaptBillvmax700
about how long did it take you? and i am no master sled mechanic by any means.
devinzz1
pull exhaust off, remove 14mm bolts holding recoil on, remove flywheel nut (Cant remember but i think it might be left hand thread), remove flywheel with a puller. From here your stator should be exposed. Remember to use the exact right size phillips head bit and ratchet cause the mounting screws are real tight. Clean any rust off flywheel before re installing.
Make sure to lock tight screws as well. Its a couple hours if you take your time.
CaptBillvmax700
i watched a video of a stator replacement on youtube but it was for an arctic cat but i figured the process would be very similar. the stator should come in the mail today and the clutch puller comes saturday. i got the puller off of amazon from 636 distribution. it is a universal clutch puller so i hope it works. i will post back up here and let you know how it goes.
shaggyzr2
You need a flywheel puller, not a clutch puller. The screws holding the stator on can be a pain to loosen up, I use and impact driver to loosen them.
U can get one cheap at a Harbor Freight!
drew24
This is what you need. Also called steering wheel puller or harmonic balancer puller. Should be able to get one at an auto parts store too. http://www.harborfreight.com/automotive-motorcycle/pullers/bolt-type-wheel-puller-set-69889.html
CaptBillvmax700
i ordered this one off of amazon. I didnt know that harbor freight had these. i hope it works.
http://www.amazon.com/636-Distribut...STJhjfL&dpSrc=sims&preST=_AC_UL160_SR160,160_
drew24
That one will work. This tool also comes in very handy at times. http://www.harborfreight.com/hand-tools/screwdrivers/impact-screwdriver-set-with-case-37530.html
