katos
Does anyone know why the fuel seems to fall away from the carbs when they sit for a while on Yamaha 700 triples?  IE mountain max.  I have even asked at shops and people just seem to live with it.  Any chance part 8CR-24301-01-00 should act as a check valve? Isn’t priming at low engine speed, has an air leak?  I assume this primes the fuel pump?
			A couple of bucks
Could be a float or floats that are varnished up and too heavy to float to the top and make the float needle seat. It Could be junk stuck in the float needle seats. At any rate, I believe the problem is related to the float bowl or float bowls.
			Excited Vmax
I believe most of the fuel pumps since '94 should have an automatic shutoff built in. You may want to rebuild or replace the pump.
			got-wood
Is there no air-box on this thing?
