98 vmax 700 clutch has cracking
I'm not sure if the rollers are different, but a primary from a 99 700 should bolt right on. If you've done any clutch tuning you should be able to swap your weights over. If the cover is a taller cover, and you have a different spring in your old clutch you'd have to swap covers. I had some cracks in my clutch and I got great deal on a viper clutch, I just swapped my weights & springs over to the viper clutch.
