sc3
I would also pull up the limiter straps... if the track is hanging then something else is binding. Are you sure you have the center to center correct?
Everything is as close to donor sled measurement as possible. I believe the front mounting point is just to low which is why the skid sits so tight on the track. I removed everything and remeasured the holes and everything looks fine other then having to move the front back half inch to fit.
You have to move both holes. If you move the front back 1/2" you have to move the back 1/2 back as well to maintain the center to center of the arms.
20151112_084010.jpg20151113_164324.jpgsuspension in and everything seems to look alright. Hopefully it works out. Noticed that the front end sits a little lower. Any suggestions on how to raise it?
Happy with the skies just wondering about front suspension. Is there a way to make it sit a little higher for clearance.
K. Don't have much left there to crank. Will leave it as is for now. Need snow first before making any more changes to the sled. Common snow!!!
