Cleaned the carbs this year. Checked the floats for adjustment (none required). All jets stock (not at any crazy elevation). Checked the oil pump cable and it's at spec, but she's still smoking pretty good. Has been since I got her last year. Cylinders are all at 125. Pulled the plugs and they're oily. (but I just installed them, so they're new) Just wondering if the cable spacing is an accurate measurement for oil mixing? Are there times when you need to adjust based on other factors? If so, what's the method? I'm used to dirt bikes where you do it based on jetting.
Thanks!
Thanks!
