Heel clicker kit question
badazzyammie
browncity
I called on a heel clicker kit and they said you don't need to change helix or secondary spring but how come every other clutch kit comes with them?
Dalton 50/40 green at 70 would be good start, load heel and tip with 5 grams each and adjust from there
Yup,now that you mention it lol. My 98 has the clickers and my 01 has the 8DN's. The clickers I believe has a 50/36 Dalton with a green spring at 70 degrees.
Sent from my XT1058 using Tapatalk
So your saying 5 grams in both holes green spring and 50/40 helix would be good for stock?
is this for a srx700? you didnt specify in your original post. If it is for a srx, youll find the stock 47 degree helix to provide lack luster performance unless you run the weights very light, its too steep of a finish angle.
what kind of riding do you do most of the time?
Sorry guys been very busy mr viper I mostly trail ride with occasional drag racing and yes 02 Srx stock for now again sorry for not responding
use a dalton 50/38 for trail riding youll find it will perform very well, use a green dot sec spring at 60-70. set up front weights with red primary, 4-5 grams heel weight, empty center and 5 grams tip weight. tight belt deflection.
