badazzyammie
I called on a heel clicker kit and they said you don't need to change helix or secondary spring but how come every other clutch kit comes with them?
These kits were designed to work with the stick secondary setup but bigger gains will be achieved with a spring and helix change.
Sent from my XT1058 using Tapatalk
badazzyammie
Oh alright what's a good spring and helix to go withThese kits were designed to work with the stick secondary setup but bigger gains will be achieved with a spring and helix change.
Dalton 50/40 green at 70 would be good start, load heel and tip with 5 grams each and adjust from there
I'm using a Dalton 54/46 I think and a green spring at 70 degrees.
That sounds like 8dn20 set up
Yup,now that you mention it lol. My 98 has the clickers and my 01 has the 8DN's. The clickers I believe has a 50/36 Dalton with a green spring at 70 degrees.
badazzyammie
So your saying 5 grams in both holes green spring and 50/40 helix would be good for stock?Yup,now that you mention it lol. My 98 has the clickers and my 01 has the 8DN's. The clickers I believe has a 50/36 Dalton with a green spring at 70 degrees.
That should get you in the ballpark,you may have to do some fine tuning of the tip weight for your peak revs.
YAMMIEGOD3:16
have to make complete changes to your clutches. especially when you change your primary setup. 3:16x (yammie tony)
I just looked at my sig and the helix I have for the clickers is a 50/39 so 50/40 should be good too.
badazzyammie
Ok thanks guys sorry took me so long been busy haven't had a chance to get on here
Backwoods M Max
What does heel clicker recommend for your sled in their setup sheet? They are just about spot on with the starting point.
badazzyammie
She told me they are already loaded when u get them I was just wondering about the. Secondary
is this for a srx700? you didnt specify in your original post. If it is for a srx, youll find the stock 47 degree helix to provide lack luster performance unless you run the weights very light, its too steep of a finish angle.
what kind of riding do you do most of the time?
badazzyammie
Sorry guys been very busy mr viper I mostly trail ride with occasional drag racing and yes 02 Srx stock for now again sorry for not responding
use a dalton 50/38 for trail riding youll find it will perform very well, use a green dot sec spring at 60-70. set up front weights with red primary, 4-5 grams heel weight, empty center and 5 grams tip weight. tight belt deflection.
badazzyammie
Is it just one green dot or is it green green green? How will that be on top end? Just curious
