russiankid
Hey guys, new to the forum and new to sledding in general. Hopefully I am posting in the correct section. I recently acquired an 89 Exciter 570 as my first sled. The sled has 1,000 miles on it and the PO has recently replaced the cooling hoses and track on it, picked it up for $600. The sled runs great, fires up on the second pull and everything seems to be in working order. I have been reading up a lot about these sleds and my research has lead me to this forum as it has the most amount of information I was seeking for.
A lot of info I found was that the 87's had a butterfly style carburetors, which was later switched over to slide carbs, and then later on the needles were switched over. My question is how do I determine whether or not I should be concerned about running lean when going from WOT to idle? It does not have decompression valves and I am sure it has the slide style carbs.
