hurricanez1990
Has anyone removed airbox and installed a aircleaner on the end of carb on a srv what jet size is recommended
Srv560
Why would want to do this?what carb r you running ? There are pro's and con's jet size sound be change a few size's all depends what carb you have and what you are trying to achieve .
Sent from my iPhone
Sent from my iPhone
Srv560
Did you look on Time line scroll down on time line intill you see( to buy or not to buy 85 SS 440.)Open the forum and you will see what you looking for.
Sent from my iPhone
Sent from my iPhone
hurricanez1990
Some say the box is restrictive would it help for more power helpin to draw more air in
Not sure about an SRV but I've read about people doing this to other sleds and it made the carbs terrible finicky.
Sent from my XT1058 using Tapatalk
Srv560
Ya, other sleds have . Have to reject carbs. Mybe to start rear low on air jet ?
Sent from my iPhone
Sent from my iPhone
toydoc
That air box will out flow the carb. Your going to draw warm air and likely make less hp
Hammer Down
And if it's a trail sled it will suck in powdery snow, then freeze and ice over, then die until the ice is defrosted off the filter.
A couple of bucks
You'll kick yourself repeatedly for doing it.
yamahamark
Don't remove it.
