Yamaha Nutz
thanks for the comments guys ........all i will say for the money i have stuck into the sled is it is one expensive phazer
Seems like you have a small gas tank, under the handlebars like on a normal sled, isn't that in use, since you have a small tank on the side?
opsled
The tank on the side is a lube tank for the skid. Not for fuel.
opsled
opsled
Ah, that explains it. Thank you.
Yamaha Nutz
yes like OPSLED said the main tank is a 2.5 gal 76 snow twister tank ..which is for the fuel ..the side tank is for the lube system for the rear skid which is a 4 point presure lube system that i run my blend of liquid through to keep the slides from sticking to the clips on the ice tracks
