Sxviperrules99
I took my pipe off of my sled today to clean it up and paint it. I removed the chrome cover off of the pipe and noticed that there was a golf ball size dent on the bottom of the pipe. Will this affect the performance of the sled or should I just leave it as it. I know the dent would cause very little restriction but I was wondering if it could cause a difference in the back pressure. Also, do I need to leave the chrome pipe cover on the pipe. I frst thought it was for looks but notice that it has insulation on it so I thought it might of been a heat shield?
Thanks for the help,
staggs65
The shield is to hold the heat in the pipe. They perform better with heat in the pipe. If you know someone with a stud welder and slide hammer you could pull the dent out. Otherwise I wouldn't worry about it
Sxviperrules99
Mu buddy has a slide hammer that he said he'd help me pull the dent out with. Thanks for the info! Also, anybody know what the best paint is for my pipe and silencer?
shaggyzr2
I use the PJI fast black Hi temp on my pipes.
yamahamark
Hi temp Header pipe paint..
Sxviperrules99
Would barbecue paint work? Lol
yamahamark
Yes it works to. I have used it before.
shaggyzr2
Any hi temp paint will work. I use the PJI because it looks close to the factory finish and it hold up well.
A couple of bucks
As far as a dent in the pipe goes, I just asked that one last week and got some great suggestions.
http://www.totallyamaha.net/forums/threads/100729-Pipe-repair?p=683979#post683979
Any hi-temp paint will work. Although I never had any luck keeping it on the pipe. Tends to flake off. Mabey if you covered up your vents the first time out w/ your freshly painted pipe. Get it good and hot without any cold air blowing on it until it is fully cured.
Sxviperrules99
Thanks for the info everyone
Thx
A couple of bucks
Is the y-pipe off?
A couple of bucks
You might still need to heat an OE pipe up in conjunction w/ the dent puller. A propane torch w/ mapp gas will get it plenty hot.
An aftermarket pipe might not need mapp gas as they are not as heavy gauged than OE.
Sxviperrules99
Is the y-pipe off?
No, the y pipe is still on
A couple of bucks
Try the next size smaller standard wrench. You will probably have to pry it on there in those tight/inside spaces.
Sxviperrules99
I tried a 9 mm but it was too small. Pretty frustrating.
A couple of bucks
10 mm is just a cooter bigger than a 3/8ths. See if a you can get a 3/8ths on that rounded off nut.I tried a 9 mm but it was too small. Pretty frustrating.
Usually golf ball size and smaller dents don't hurt performance, at least on my motorcycles. I've repaired dents on several 2 stroke dirt bike pipes. I have adjustable plugs the bolt onto the ends of the pipe. I pressurize the pipe to about 40 psi and heat it with a map gas torch. I start heating the outer edges of the dent and work inward in a circular pattern, the pressure will make the dent disappear. I heat the dent until it starts to glow dull red in color.
Sxviperrules99
It's even a little smaller than a golf ball size... should I just paint it and not worry about it??
You probably can't tell any difference, but if you're like me, you can't stand it knowing there's a dent in a location that can't bee seen
Sxviperrules99
You probably can't tell any difference, but if you're like me, you can't stand it knowing there's a dent in a location that can't bee seen![]()
Yeah I'm like that too lol but I think I could live with it.
