Sxviperrules99
I think I'm going to upgrade my track on my sx viper in a couple weeks but wanted to make a few things sure... first of all, the track I found is a studded 1.75 Camoplast backcountry. First question is can I run the studs if I keep my hest exchanger protectors on but go to 8 tooth drivers? Or would I have to remove the studs?? Second question is if mountain maxes have the same drive shafts that sx vipers have... I found a used drive shaft with 8 tooth drivers already mounted and would just purchase that as it is cheaper and I wouldn't even need a press to put the drives on.
Thanks,
Thanks,
