iasledder
Having idle problem. Carbs cleaned and sync'd, valves cleaned, good spark. Compression good all cyls. When off of choke won't idle on all cyls. Primary appears to be #1. Won't run on 2 or 3 individually, runs on #1 ok. If choke is on part or full runs ok. increasing idle close to clutch engagement runs ok with choke off. Looking for suggestions idle all 3 cyls. Thanks for looking.
