Rebmo
I'm adding a 12v Cig Ligher Socket to my Son's 2001 SXR-700. Not for a cig lighter, but to run NAV, Charge phone battery, jump if needed, etc... Anyway, It has a battery/Electric Start and want to add the socket on the front flat panel area of the raise up hood. I will need to bundle a hot and ground from the socket to the front of the hood, and then back down left side, under engine, and up to battery. At least that's the plan following some existing wiring and tie wrapping. I have 18ga red & black wire, but would like to find a sheath/cover for the wiring to protect from abrasion, wear through, and heat.
Any suggestions for a 2-wire covering for about 8ft of wire that will protect it?
Thanks, Reb
Thanks, Reb
