Mainerider1
That's what Im attempting to do. Sled has 2900 miles with ES and reverse.I took the muffler off to check the level and condition of the oil.It seemed to have a lot of silver flake in it but the level was good. I took the battery and battery case out and it looks like there are 4 bolts around the edge holding the cover on.I loosened them up but seems like there is more holding it on .I was trying to back the cover just enough to drain the oil and clean it out some and maybe check the chain tension.I was hoping not to have to unhook all the linkages.I noticed theres a bolt in the middle of the case but I didn't want to start pulling bolts I don't have to and having things start falling apart and end up in a mess.Anybody got a pic of the bolts that need to be removed so I can get the case cover loose? Thanks,,,,after this its done and ready for snow.
