chazdo2
Does anybody know how much oil goes in the chaincase or how tight the chain should be?
			sledtillsed
There is a Philips head screw  at the back of the case. U have to get at it through the footwell with a long screw driver .  Pull that screw and fill till it comes out.
Re tension. Pull cotter pin on tensioner bolt ( back side as well) thread in till it stops by hand back off approx 1/2 turn and replace pin. This should really be done with cover off to confirm deflection
Yamaha Nutz
320cc or 10 oz of sae 10W30
			caravanman
Welcome to the site chazdo2.
My 80's sleds (79-80 Enticers and 82 440's) as well as my 90's machines all use gear lube.
I use synthetic 75w90
							Yamaha Nutz
comes right from the factory service manual what I posted
got-wood
Operator's manual recommends 10W30 as well.
			caravanman
The Exciter must be a different animal then? I have never had one.
You learn something new all the time.
