Hello all,
I just picked up my first Yamaha sled and need some guidance with the pull cord guides location. Currently my pull cord is rubbing on the chain case and I believe that there is a guide missing. Could anyone post pictures of their sled to get an idea on what parts to buy? or maybe I can fabricate something up to not chaff my pull cord and cause it to break all the time. Any advice would be appreciated!!
Thanks!
Thanks!
super1c
Super Moderator
I dont have my sleds here but if you shoot a pic we can say if its right or not!
There's no guide missing.. It's running on that little tab on the top of the chain case right?? There is a hole on said tab too. That's how it's supposed to be and it drove me crazy as well...The older vmax's (I believe 94-96 had a guide) I picked up one off fleabay that looks like piece of small bent tube, but I've also seen them that look like a piece of wire bent that formed a circle. I replaced my recoil rope with Amsteel also.
The guide is--> Yamaha part number 8BB-15758-00-00
The guide is--> Yamaha part number 8BB-15758-00-00A couple of bucks
I've fashioned a guide by using one of those 1 foot long springs that are usually beside the screen/storm door stuff at the h/w store.
I'd be interested in seeing a pic of that setup
Yeah id be interested in seeing a picture as-well. I called the local Yamaha dealer and ordered a guide from them. It was only $20 so I went ahead and ordered it to see what I am missing on the sled. They said that there is a guide near the chain case. I will snap some pictures of the setup I have now and when the new guide is installed.
A couple of bucks
That was on a Phazer I no longer have.I'd be interested in seeing a pic of that setup
I have it. It's a spring that attaches to the recoil housing and basically flops loosely on the other end. I was thinking about replacing it with a piece of rubber tubing all the way up to the pull handle. Probably have to poke some drainage holes in it. I honestly think Yamaha assumed most of these sleds would have e-start and didn't worry much about a pull start guide for a mere backup means of starting. Seems like a poorly thought out design.Yeah id be interested in seeing a picture as-well. I called the local Yamaha dealer and ordered a guide from them. It was only $20 so I went ahead and ordered it to see what I am missing on the sled. They said that there is a guide near the chain case. I will snap some pictures of the setup I have now and when the new guide is installed.
Sent from my SM-G900V using Tapatalk
caravanman
My brothers SRX 600 cord rubs right on the chain case. It was like that when new.
Backwoods M Max
The guide is the chain case. It's suppose to rub on it.
yamahamark
Yep that's the guide
2003VIPERER
My viper looks exactly like that, I used a small spring and put it on top of the chaincase cause that is where my pullcord keeps fraying and breaking. no breaks last season
devinzz1
Should be a little mount that holds the coolant line that boxes the pull cord in but thats where it should be. Theres not much friction at all really.
super1c
Super Moderator
^^^X2. You can also get the plastic guide and holder off a viper and that would work good.
Backwoods M Max
If your pull cord looks frayed or you just want piece of mind replace it with a piece of 1/4" amsteel, samson 12, or dynema rope. those are trade names for high strength spectra sailing rope. If you get it from a marine wholesaler or eBay you can usually find the stuff for just under $1.00/foot. It's the same stuff you see advertised as cobra rope but doesn't cost $35 for 6' of it. The breaking strength is around 4000lbs and it has a very high breaking strength with no stretch. If your sled ever dies you can cut the rope off and use it to tow the thing home with!
