Larry Bryzelak
I have a 99 srx 600. I just rebuilt the motor last year and maybe but on 100 miles of riding. I had a low end bog so I cleaned the carbs including the fuel screens and it does the same thing. So then tried to adjust the fuel screws from 1 1/8 to 1 1/2. It did the same low end bog once again. Keep in mind I bought this sled with a blown crank. So I was reading on here that when you adjust the fuel screws you turn them in until there snug. Then set your turns. Well my question is what happens if someone turned them in more then snug. I say this because I noticed when I set the screws to my spec I can see the needle part of the fuel screw sticking up in the carb intake. And they don't look the same height. Could this be from an over tighten of the fuel screws? I hope to get some feedback back on this because I have not seen a post about this issue. Thanks.
