mtnviper700
ok so far i have a 97 sx 700 ported , reichard's pipes, carbon tech reeds,reed spacers, heel clicker 40-10's , wiper track ect.... looking to get higher engagement and better belt grip/ shifting anyone here know of good setups for ice 660"???? gearing and clutching combos sled has done extremely well in 400-500feet taken few trophies home ... gonna go out and test this weekend hopefully just looking for a good starting point can fine tune from there...never ran ice before..
staggs65
What's your clutch setup now? I'm not a redhead guy so I can't really help you but it will help everyone to know your current setup
mrviper700
VIP Lifetime Member
if your set up well for 500ft then to race 660ft youll need to change the gearing a little bit and that will make you need to adjust your primary weight slightly to keep the rpms the same, but wouldnt require a new set up. notching the weight is the way to get the engagement up.
mtnviper700
thanks for the help guys just ordered a new set of heel clickers sending them to get cut ...i swapped the gearing out now running a 21 top 40 bottom ...praying for colder weather now..
