setting up race clutching now stumped...help???
mtnviper700
maine
ok so far i have a 97 sx 700 ported , reichard's pipes, carbon tech reeds,reed spacers, heel clicker 40-10's , wiper track ect.... looking to get higher engagement and better belt grip/ shifting anyone here know of good setups for ice 660"???? gearing and clutching combos sled has done extremely well in 400-500feet taken few trophies home ... gonna go out and test this weekend hopefully just looking for a good starting point can fine tune from there...never ran ice before..
if your set up well for 500ft then to race 660ft youll need to change the gearing a little bit and that will make you need to adjust your primary weight slightly to keep the rpms the same, but wouldnt require a new set up. notching the weight is the way to get the engagement up.
thanks for the help guys just ordered a new set of heel clickers sending them to get cut ...i swapped the gearing out now running a 21 top 40 bottom ...praying for colder weather now..
