Mschimmens
Hi
I am looking to replace my track and have found a 151" x 15 x 2.52 x 1.25 track off a Arctic cat bear cat. I know the pitch is correct for the machine but my question is will the existing sprocket support the longer lugged track?
I have read that a 9 tooth sprocket will only support tracks lugs up to 1" and you need an 8 tooth sprocket for tracks of 1.25". I am not sure how many teeth are standard on my sprocket.
Any insight would be greatly appreciated as I think this new track would be a great addition to my machine.
Thanks.
Thanks.
yamahamark
As long as everything else is the same it will work and you can always trim the track if you need to.
Hope that helps...
Hope that helps...
francis6667
you are supposed to have 8t sprocket on your sled and i think it's supposed to be ok for 1 1/4 track lugs`,if not you can put 7t ,i did it for putting 2 inchs track lugs on the same sled.
