Sxviperrules99
So I got my motor all together and when I looked at the gasket prior to installation it appeared to not have a way to install it but I read today that there is a specific way to installing it.. the way I put it on has the little tab that sticks out in front of the motor on the left side if you are sitting on the sled. If I would have flipped the gasket over it would be on the right. Did I put it on wrong and if I did must I correct it?
Thanks for the help,
Sxviperrules99
Just read on another forum which informed me that it is on upside down... I did run it for about 5 minutes.... will it still be ok to reuse the gasket?
super1c
Super Moderator
Yes OK to reuse. Just use some copper spray.
YAMMIEGOD3:16
elevation up, all ya need to watch. 3:16x (yammie tony)
